67 sway bar - NCRS Discussion Boards
67 sway bar
  • larry linkous
    67 sway bar
    Did all 1967 corvette's use the same size rear swar bar, regardless of the motor?? 9/16th ?? Thanks Larry
    • 43221
    Re: 67 sway bar
    Larry-----
    No, there were 3 different size FRONT sway bars used. All small blocks received 3/4" of GM #3831971. Big blocks received a 7/8" front bar of GM #3871318. Cars with F-40 HD suspension received a bar that was 15/16" and of GM #3831972.
    ALL 1967 Corvettes with big block, regardless of which engine option or with/without F-41 received a 9/16" rear bar of GM #3872451. NO small blocks received this bar for 1967 or any other year.
    • Jon #40768
      Re: 67 F40 15/16" sway bar?
      I had a guy go into the gm computer and he could not find that a 15/16" bar was ever sold over the counter as a servicable replacement. Is that true? Does any one supply an eaxact repo of this bar?
      Thank you
      Jon
        • 43221
        Jon-----
        The 15/16" front sway bar used for cars with F-40/41 suspension was GM #3831972. This bar was available in SERVICE from October, 1962 until June, 1975 when it was discontinued.
        As far as I know, there is currently no exact reproduction (or, even, an inexact reproduction) of this bar available.
        • Jon #40768
          Re: 67 F40 15/16" sway bar? Thank you *NM*
