1969 Alternator Information - NCRS Discussion Boards
    • 43203
    I uncovered some interesting information regarding 1969 alternator applications today and I thought that I'd present it here. I was looking at a friend's original owner, 1969 L-46 coupe. This car is a 4 speed, non-TI, non A/C. The alternator on it is unquestionably original. It has all of the unique-to-1969 Corvette alternator case configuration elements and the owner absolutely knows that the alternator was never changed.
    The interesting thing is that the alternator is a GM #1100882. The alternator still has the "NS" ink-stamped broadcast code clearly visible on it which is also the known code for the '882' alternator. The date code is "8K25" which is consistent with his car's build date (but only a few days before). The alternator is stamped 61A for 61 amp. Apparently, the '882' alternator was used for applications other than those for which it is generally regarded to have been used. Plus, this useage and date would indicate that it was used very early in the 1969 model year and not just later in the model year.
    Unrelated to this, but related to the '882' alternator, is the fact that I have another '882' alternator which I purchased some time ago [not for sale]. This unit has an incorrect split ring case half but the drive end case half (with the numbers on it, of course) is the unique-to-1969 Corvette configuration. I am VERY confident that this is an original Corvette unit and has not been "re-stamped" or otherwise tampered with. The date on this unit is "8J17". The interesting thing is that this unit is stamped 55A for 55 amps. Generally speaking, the '882' unit is considered to be a 61 amp unit and every spec that I have seen for it indicates that it is rated at 61 amps. So, either this 55A stamping is a mistake or the '882' was manufactured with 2 different ratings. That's VERY unusual for any given GM part number.
    INTERESTING!
    Of course these cases place burden of proof upon the owner under our rules, but I don't think I'd doubt authenticity when you have as much evidence as indicated (date code, rubber stamp ID, emboss). We know there were times when the factory substituted 'downward compatible' parts to balance inventory and keep the line running....things like 5-blade fans on A/C cars and once in a while 7-blade fans on non-A/C cars.
    But the one '882 who's case is also embossed 55A vs. 61A is the head scratcher! That means it's either a Delco Remy emboss 'opps' or there's something we don't understand here....
    It'd be interesting to pull both alternators and run 'em to max output on a charging test stand to see how they were actually built by DR (what was configured inside for rotor & field windings). Is there a bona fide performance difference between the one embossed 55A and the one embossed 61A?
    • Mark #28455
      Re: INTERESTING!
      That'll make you scratch your head! My very early L88 (late Oct.68) has an original 825 alternator with the 61A rating, so I don't know why the 882 alternator would be 55A.
      • Dick W.
        • 10483
        Re: 1969 Alternator Information
        It would be tough to justify on the judging field, but I think there is enough past history of factory snafu's to believe that the 55a was accutally a factory unit. But is is not "typical factory production".
        Dick Whittington
        • Tom D.
          • September 30, 1981
          • 2132
          Alternator Business Comments
          The folks in Anderson, IN did make some mistakes. When Delphi Corp. was created there was a significant effort to improve on that, and keep the passenger car generator business. However, they found it very difficult to compete.
          Some years back, GM & Delphi agreed to sell the non-passenger business to a new company called Delco Remy America. (Delco Remy America is not part of GM or Delphi).
          After many attempts to sell the rest of the generator business, Delphi Corp. is now in the process of simply leaving that marketplace.
          https://MichiganNCRS.org
          Michigan Chapter
          Tom Dingman
          • Gary Bishop
            Re: INTERESTING!
            Jack: Have you seen any 8" blade fans on Mid-years? I know the AIM shows it was called for at one point but I understand they were not put into use. Some Judges say "if it is an 'air' car it MUST have 8" blades.
