Need help identifing this fan application. - NCRS Discussion Boards
  • Zachary K.
    • March 1, 1986
    • 162
    Here's how it's stamped on each blade of the fan.
    E6 - obviously the date
    921239
    SC
    Any idea's ? Thanks for the help, Zach.
    1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
    1969 L71 LeMans Blue, Bright Blue Convertible
    1970 L46 Monza Red, Light Saddle Convertible - Duntov
    1976 L82 Classic White, Firethorn
    2013 LS7 Black, Ebony, Convertible
    Moved on -
    2006 LS2 Black, Ebony, Convertible
  • Gary Bishop
    Re: Need help identifing this fan application.
    It must be for an Air Vette that needs the bigger fan blades. The AIM shows one is called for but was NEVER really used. You need it to get by with some of the Judges.
      • 43234
      Zachary-----
      Assuming that "921239" is a GM part number (which would be very unusual if it's stamped on every blade of the assembly), it's NOT a Chevrolet part number and it was never used on any Chevrolet. I can't find any record that such a part number was used on any other GM car or truck, either. Of course, it may be a manufacturer's ID number of some sort, too.
      • Craig S.
        • June 30, 1997
        • 2471
        It is a GM 3863137 "optional" production fan
        Joe, Zachary, and Gary - this is a GM fan, but Joe you are correct the numbers are not the GM part number. Pete Lindahl and I have had discussons back and forth on this fan, and it is the 18" "optional" fan used on AC vettes in midyears with the "dice" rivet pattern. By "optional", it is NOT an orderable optional fan, it is the "other choice" vendor or 2nd source supplier the line used. This fan was apparently never sold over the counter, only used on the build line. I have a fan in my collection of fans like this. The part and date are on each blade, so I believe it was the sippliers designation for for blade before fan assembly. BTW, the details of this fan are in Noland Adams Volume 2 restoration guide on page 340, and the GM P/N of the fan is 3863137. This is also listed in the AIM....Craig
        • Craig S.
          • June 30, 1997
          • 2471
          By the way, mine also has the same "E6" code, if it is a date or not, I am not sure, I assumed it meant May of 1966 but maybe not. The 921239 and SC are also there, on each blade. As I recall, Pete has one of these on one of his cars, and his may not have been the "E6" but the rest was the same. Possibly this supplier built a batch of blades and stockpiled them, and later assembled fans or built a large batch. I plan to use this fan on my 67 L79 KH coupe....Craig
          • Zachary K.
            • March 1, 1986
            • 162
            This fan is on my '67 AC convt. with Oct. 4 '66 build date. Years ago at flight judging, I was told this fan was incorrect, due to the mushroom head rivets and one blade with what appears to be balance weights. The car has been judged possibly 5 times since that first time and no one's picked on it until the N.C. Regional. I have removed the fan and am trying to do some research on it just to see what's correct. Thanks for the help Joe and Craig.
            Moved on -
            • Craig S.
              • June 30, 1997
              • 2471
              Zachary - yes, it is the controversial fan based on the TIM&JG. But I wouldn't rule out it is original, however, it may be easier to loof for an 18" 5 flat head rivet fan. I also have the other correct fan but with mushroom rivets, so that would be an issue too...since it was earler than 67 supposedly. It is not easy to find the 18" vs 17.5" fans with the correct rivet type...Craig
