Master Cylinder Rebuild - NCRS Discussion Boards
  • Jeremy Hedges
    I have an original '65 power brake master cylinder that I need rebuilt. Does anyone Know of a good source?
    Jeremy Hedges
    #31711
  • Rick A.
    • July 31, 2002
    • 2147
    Re: Master Cylinder Rebuild
    White Post Restorations - White Post, VA
    One Old Car Drive
    Post Office Drawer D
    White Post, VA 22663
    (540) 837-1140 Fax 837-2368
    Ask for Billy or "W.R.
    website - http://www.whitepost.com
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • Tracy C.
      • July 31, 2003
      • 2739
      Jeremy,
      You might check ads in the Driveline or you might just check your local yellow pages for a small rebuilder in your home town. There isn't anything too complicated about this job and you will have a chance to speak to the shop owner face to face.
      I've found most owner/operator rebuilders understand the "restoration mentality" and will oblige your request to have your original casting rebuilt and returned without a problem. You can also save the extra shipping and associated cost of a specialty shop. Same goes for replating your lid.
      Good luck,
      tc
      • Rich G.
        • August 31, 2002
        • 1397
        I just had a 68 PB MC done (SS sleeve) by Apple Hydrolics here on LI. They did a fine job. They are local for me, so I dropped it off and picked it up 5 days later. As the previous post said, many shops can do this. If there is one close to you, that's an option.
        Rich Giannotti
        • Larry S.
          • August 31, 2000
          • 356
          I also used white post.Real quick turn around,Just tell them you need it painted black when there done.
          • Brian McHale
            WhitePost. Fastest turn around in the hobby. AAA++++
            • Gary Cederman
              I would not go with WhitePost if I were you! They installed a wrong part in my M/C for my '63 and it messed me up for days. When I told them about it, they just sent to me my original part which I had to install.
              No, "sorry" or "We will fix it.", nothing! As far as I am concerned, they did not stand behind their work. Very shotty.
              In my opinion, WhitePost is a bad deal.
              • Rob A.
                • December 1, 1991
                • 2126
                Regardless of who rebuilds it for you, make sure you tell them(in writing) if you want it painted or not. If you're not specific they'll probably paint it some brand "cast iron" color....and they sometimes paint the inside too, which you don't want. I bought mine already rebuilt, and whoever did it painted it cast iron color inside and out and I had to strip all the paint off.
