62 PG slipping problem - NCRS Discussion Boards
    • November 1, 1991
    • 146
    Beginning to get some slippage when the transmission gets warmed up real good. Have always had a problem with the fluid leaking out when the car sits for extended periods. Is there any addative you can think of that would help? It's still all original and I'm trying hard not to have it rebuilt, if possible.
  • Rob Dame
    Re: 62 PG slipping problem
    Try adjusting the bands.
    Lucas makes an additive that may help the slip and will also help the leak.
    Rob
    • Roy B.
      • February 1, 1975
      • 7044
      If your getting slippage when it warm up , sounds like the clutch piston seal is leaking causing the clutch piston to shut slowly. Leaking can be a hard filler tube O-ring bad.A 62 aluminum trans. is as simple as it get to rebuild.A kit is about $100.00. Believe me if you can do any mechanical work your self , you can rebuild that trans. Common seance will help you understand it as you take it apart and rebuild it. Why spend thousands to do a hundred dollar job you your self can do and have the satisfaction you did it .Just get a old 62 up PG overhaul book.
      • mikemccagh
        Roy: can the same be said of the cast iron powerglide rebuild? i need to tackle the PG in my 57 250 hp vette one of these days. mike
        • Mike M.
          • April 30, 2003
          • 104
          Roy is correct, probably have broken/cracked seals. And yes, PG's are easy to rebuild, just a pain to get in and out of the car. Try a can of KW "Trans-X" first. If the seals are not too far gone it will expand and soften them. Just remember that Trans-x is a band aid and not a permanent repair.
          Mike
          • John M.
            • January 1, 1999
            • 1553
            Mike,
            The old cast iron PG trans is just as easy to rebuild. Roy's modesty is probably preventing him from telling you that he made a real good video that shows how to rebuild one step-by-step! C Central used to sell them. I think I still have a copy and if you let me know when you need it, I will lend you mine.
            Regards, John McGraw
            • mikemccagh
              thanks,john. mike
              • Roy B.
                • February 1, 1975
                • 7044
                OK Mike ( Modesty ME??) I owe you one!.
                • Dennis C.
                  NCRS Past Judging Chairman
                  • January 1, 1984
                  • 2409
                  When all else fails, time for a 4 speed... *NM*
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    Spoken like a true slap happy gear banger !! *NM*
                    • Dennis C.
                      • January 1, 1984
                      • 2409
                      TC - That's what I'm talk'in 'bout... DC *NM*
                      • Dick W.
                        • 10483
                        Re: TC - That's what I'm talk'in 'bout... DC
                        Real Corvettes have three pedals in the floor and an oar in the console
                        Dick Whittington
