1970 Corvette Engine Rebuild - NCRS Discussion Boards
  • Kelby
    What's the going rate for a rebuild on my '70 vette's 350ci/300hp engine?
  • Dave F.
    • December 1, 2003
    • 508
    Re: 1970 Corvette Engine Rebuild
    In the Cincinnati area, my 68 L79 was $1500 (included disassembly, gaskets, rings, machine shop work, and assembly) plus the cost of valves and cam kit, and fuel/water pump/carb rebuild costs. Then there are costs for paint, plugs, points, wires, coil, voltage reg., thermostat, belts and hoses added to that.
    • Brian Monticello
      I just paid ~$1300 for the following machine work:
      -Cut crank
      -drill/tap crank snout
      -bore
      -hone w/torque plate
      -cut flywheel
      -balance rotating assembly
      -press fit rods/pistons
      -polish piston pins/hone pin bores
      -fix small crack by head bolt on deck
      -hot tank
      -cam bearings (installed)
      -freeze and galley plugs (installed)
      I'm doing the assembly... pistons ran about $180 and I bought a set of rebuilt heads for $550. New aftermarket Rods were around $240. Cam and Lifters $160. Water pump $40
      Add in another $300 for gaskets/rings/hoses/bearings.
      My total cost for the engine only was about $2800 + many hours of researching / shopping / and assembling. I probably paid too much for the machine work but everything here is expensive.
      If you're going for broke (literally) add in another $750 for so for complete distributor and carb rebuilds.
      I converted my engine from NOM 327/??? to 327/365 so I had to find new intake, carb, air cleaner, oil pan, studs, windage, tachometer, oil gauge needed a new radiator, and countless other tubes, stickers, and widgets. I stopped counting so I wouldn't have to answer to my wife. I'm probably $5000 into this project and the value of the car probably went up $2000. If you're like me you'll need to buy a hoist, stand, and many tools..... oh man my pocket book hurts.
      Now I understand why people say $45000 invested - selling for $30k..but I digress.
      HAVE FUN.
      Brian
