I've read a lot recently on the websites for the various valve train manufacturers regarding pushrod length. I'm replacing the cam and lifters in a '66 390HP. If I'm putting in an original(flat tappet) spec cam, with stock rocker arms, heads etc, is it still necessary to measure for the correct length pushrods needed? I planned on just re-installing the stock, 5/16" rods I removed, but they insist I need to measure for the correct length rod needed after installing the cam and the heads.
'66 BB ENGINE REBUILD/PUSHROD LENGTH
