removing clear silicone - NCRS Discussion Boards
  • Pat #25912
    A previous owner of my '59 used clear silicone to attach some of the door rubber weatherstips. I would like to clean the silicone off the base clear paint. Any suggestions as to what could be used would be appreciated.
    • May 31, 1974
    • 8396
    Re: removing clear silicone
    i know of no solvent that will soften silicone without also playing hell with your paint. matter of fact, i know of no silicone solvent . I employ Mr Buck/Old Timer/Case/Barlow etc along with mr fingernail. tedious work. good luck, mike
    • Byron Martin
      3M makes a rubber wheel that is designed for removing pinstripes. It fits in a drill and works well removing weather strip adhesive and silicone. You can pick one up at any automotive paint store and it wont hurt your paint. Good luck.
        • 43241
        Pat------
        Gasoline is a solvent that will degrade and soften silicone RTV (that's also the reason why you should NEVER use silicone RTV for any application that's exposed to gasoline). However, I like Byron's suggestion better.
        • Ed Jennings
          The rubber wheels work well for that sort of thing. They are designed to be used with a an air tool at fairly high RPM, but should work ok with an electric drill. They typically cost about $13-14.
          • Bill W.
            • March 1, 1980
            • 2000
            DONT use the rubber wheels on fresh paint ! It works great on oem paint but not on repaints. I would try Mikes idea your finger nail or a plastic razor blade. You can also use dupont prep sol ,lacquer & enamal cleaner,3Ms adheasive remover,or my 1st choice dupont 3812 enamal reducer(be very careful with the 3812 it WILL soften & dull the paint). throw the weatherstrips away you will never get weatherstrip adheasive to stick.Bill
            • Bob Simard
              Removing Clear Silicone
              I have used Brake-Kleen to soften and remove silicone gasket material from valve covers. If it won't damage your paint, it should help release the silicone.
              • Richard E.
                • November 1, 1976
                • 200
                I spent days removing lots of silicone from the windshield frame to body channel, trying all types of solvents, and even heat. Like Elliot Ness, that stuff is untouchable. Even tried a new Permatex product, SILICONE STRIPPER, but still no luck. Ended up carefully removing the bulk with a razor, but not down to the painted areas. From there, it was all left to the fingernail, as Mikey says. Luck to you, Dick.
                • Jack H.
                  • April 1, 1990
                  • 9906
                  Silicone RTV will dissolve nicely....
                  if immersed in conventional lacquer thinner. Unfortuantely, so will any surface that's painted!
                  • David Z.
                    • April 1, 2002
                    • 181
                    Hey all you fingernail scrapers! Get yourselves a few Lil' Chizlers. Great, hard plastic scraper that is the world's answer to busted fingernails. Safe on most surfaces too. Try Signs Plus Banners at 800-635-6897. Bag of 10 - 5.99; bag of 25 - 12.99
                    No kickbacks or connections, just one of the best prices I've found.
                    Dave Z
                    Dave Zuberer
