C1 clock part #2279015 - NCRS Discussion Boards
  • James B.
    • September 30, 2005
    • 115
    What year 'Vette does clock #2279015 go to?
    Jim
    '59 #5366
    1959 Corvette Registry, Webmaster
    • 43240
    Re: C1 clock part #2279015
    Jim-----
    GM #2279015 is NOT a clock used in a Corvette or any other car. GM #2279015 is a spring for a rear axle electric shift motor assembly used for 1956 through 1972 Chevrolet and GMC Series 60 and higher trucks.
    • James B.
      • 115
      Hi Joe,
      Thanks for the information- That was the only part # I saw on the clock, and it was located on the back side in the lower right-hand corner. Is there another place on the clock where I should be looking?
      Jim
      '59 #5366
        • 43240
        Jim-----
        IF there is a number it should be on the back. It may be ink-stamped or on a paper label. A lot of the time, though, clocks don't have a GM part number to be found on them. The clocks were manufactured by outside vendors over the years (Westclock, Borg, etc.) and I don't know if it was a GM requirement to include the part number on the unit.
