I have a 1967 coupe with 327/300,auto,air. Completely stock except pertronix ignition. The car will simply not idle properly and will die when put into gear. The carb is a brand new Holley 3810(original type). Spark plugs are new. I have pretty much tried it all but I think I have a timing adjustment problem or maybe a vacuum leak or some thing I really don't understand.
I do know when I set the timing,I disconnect the vacuum advance and set it to 6BTDC/700RPM as per the book. When I reconnect the vacuum advance, the idle races to 1500RPM and the timing is 30 degrees advanced. By the time I get the idle to operating range the car will hardly run and will die when put in gear.At this point the timing is quite retarded. The only mark on the advance can is "B1" if that means anything.
I really don't know if any of this is relative, but I truely need input on whether it could be something to follow.Or any other direction you may have. This car has not run properly since I got it last year. Any direction will be appreciated. Thank you in advance for your input. The next step is to sell the thing and buy a C5.
