clock lens - spare tire carrier 1965 coupe - NCRS Discussion Boards
  • Rick Hendel
    I have a lens that need t be replaced in the clock. Can anyone tell me the best way to remove the clock lens. Lastly can anyone tell me the proper color of the fiberglass spare tire carrier for a 1965 coupe. Thanks Rick
  • Mike M.
    • May 31, 1974
    • 8396
    Re: clock lens - spare tire carrier 1965 coupe
    Remove clock from dash, turn upside down and you'll notice 3 or 4 areas where the twopiece main body of the clock is bent over on one another. with a screwdriver, rotate the blade to uncrimp them. then seperate and replace the lense after you've removed the knob from the re set shaft(carefully). nows a good time to dress the points. good luck, mike
    • Mike M.
      • May 31, 1974
      • 8396
      PS tire tub natural dark gray fiberglass,mike
