C1 window regulator - NCRS Discussion Boards
C1 window regulator
  • rod seay
    C1 window regulator
    Does anyone know how to get these out of the door? Does it come out the top? How bout replacing them. Any tricks needed?
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 window regulator
    Rod,
    You must remove the guide assy from the bottom of the door post prior to removing the regulator. It is impossible to do otherwise. There are two cap screws in the post and one at the bottom of the guide that anchors the guide to the door structure. This is also the bolt that allows in/out adjustment of the top of the door post. After the guide is out, you will need to crank the regulator to the right position and it will slide right out.
    Regards, John McGraw
    • Larry P.
      • June 30, 1999
      • 481
      After what John said to do, it comes out the larger square opening.
      Larry
