C2 Wheel Size - NCRS Discussion Boards
C2 Wheel Size
  • Mark H.
    • July 31, 1998
    • 384
    C2 Wheel Size
    I have seen various sizes in my research, and am trying to verify that the standard '64 steel wheel was 5.5" wide, the '64 knock off wheel was 6" wide and the '67 rally wheel and knock off were both 6" wide. Is that right?
    • 15674
    Re: C2 Wheel Size
    You are correct! To expand, all '63 to '66 base steel wheels are 5.5" wide and the wheels used in '63-'64 will not fit on later disk brake C2s. The '64-'66 KOs are 6" wide and only vary by wheel finish (unfinished in '64, painted dark gray for '65 -'66 to hide brake dust) and trim cone finish - bright chrome except '66, which has a "brushed" finish.
    Both the base '67 Rally wheels and optional bolt-on aluminum wheels are 15 x 6.
    The 5.5" inch steel wheels have +0.44" offset. The '67 Rally, bolt-on aluminum and prior KOs (including adapter) have +0.060" offset.
    • Mark H.
      • July 31, 1998
      • 384
      Re: C2 Wheel Size
      so I'm thinking a set of P4000s on '67 Rally Wheels should fit fine on a drum brake C2, if the bank account can't yet swing the knock offs, as the offset is the same as the original knock offs. True?
        • 15674
        Re: C2 Wheel Size
        215/70R-15s on '67 6" Rally, '67 bolt-ons, or KOs should not interfere with
        C2 fenders, and all the above wheels have the same +0.060" offset. When you measure the offset of KOs you have to include the adapter as I stated.
