C2 SBC Exhaust Manifold Bolt - NCRS Discussion Boards
  • Brian Monticello
    I need one ram horn exhaust manifold bolt and am about to place an order with gmpartsdirect.com. They list two parts:
    3841724 @ $3.20 qty 1
    3733134 @ $2.08 qty 5
    Anyone know which is the right part #?
    Thanks!
    Brian
    • 43240
    Re: C2 SBC Exhaust Manifold Bolt
    Brian-----
    It depends which bolt you need; 2 different length bolts are used for small blocks with "ram's horn" type manifolds. The end bolts (2 on either end of each manifold) are the "short" bolts. These are GM #3736035 and are 1-1/4" long. The 2 bolts at the center positions are the "long" bolts. These are GM #3733134 and are 2-27/32" long.
    The GM #3841724 bolt is 3-11/16" long and is not used for your application.
    • Brian Monticello
      THANKS! *NM*
