Fiberglass bonding fix - NCRS Discussion Boards
  • Anthony C.
    Infrequent User
    • December 1, 2003
    • 6
    While removing the R/H headlight assembly on my 1980 coupe I found that the fiberglass just behind the headlight door area was not attached to the metal structure attaching it to the frame. This causes the area to bow up and rub hard on the headlight door. It looks like I can re-bond the area in place. Question is, what is the best adhesive to use and are there any procedures I should follow to do this right the first time.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Fiberglass bonding fix
    Tony I use Lord Fusor T-25 for this type of repair. Lyle
    Lyle
