396/427 CRANKSHAFT INTERCHANGE - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Other than normal balancing, does a 396 crankshaft need anything special done to it to be used in a 427?
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 396/427 CRANKSHAFT INTERCHANGE
    Rob - the 6223 is used many times in 427 rebuilds, the only difference as Joe mentions is the rebalance. As I recall, one of the middle counterweights is wider in the 7115 crank. It seems most 427's that come apart frequently have a 6223 vs 7115 in them anyway, maybe they have been gone throgh before by now and the original cranks are gone. I would be curious if any known original engines from folks on this board had 6223 forgings instead......but probably not as that would be a special rebalance option at the engine line....Craig
    • Rob A.
      • December 1, 1991
      • 2126
      Thanks....I'll be taking apart a '66 390HP engine this week and wanted to be prepared in case I needed a new crank for some reason.
      • Craig S.
        • June 30, 1997
        • 2471
        Rob - for the price at Howards Cams, you can't beat it. Let us know the forging in the 66....Craig
