'60 window channel - NCRS Discussion Boards
'60 window channel
  • Don H.
    • December 1, 1981
    • 1487
    '60 window channel
    Does the '60 rear window channel (attaches to rear of door with two phillips screws) have anything in it? I have the felt / fuzz kit for the front and top opening but nothing for the rear. Mine was just painted black and very greasy. Thanks for any help, Don H.
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: '60 window channel
    Don...
    Yes, a black fuzz type material goes in the rear run. I used strips from a black sweat-shirt that makes the window easier to roll up & down.
    Rear window run liners from supply houses make this task a real grind.
    • Ed Jennings
      The liners supplied by the usual vendors is almost universally reported to be too thick. I use material from an old convertible top with the vinyl side glued to the channel and the fabric side to the window. I use a square handled punch that is just the same width as the window to smooth out the fabric. You must have a smooth job with no wrinkles.
      • Joe Maulsby
        Don, please check you e-mail, I need your help on a 1960 fastener question.
