C1- Window Crank Handle - NCRS Discussion Boards
+ More Options
Posts
  • Dennis A.
    • April 30, 1999
    • 1010
    The 1961 AIM for installing thw window crank handle shows a (plastic) spacer behind the crank handle followed by the door panel, the spring, and then another spacer that covers the foam seal. Question? Is the AIM correct, that an additional (plastic) spacer does fit between the foam seal and the spring? If this is correct, which direction does the triangle shaped spring face?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1- Window Crank Handle
    Large end at the door handle behind the door panel
