AC Delco brake parts - NCRS Discussion Boards
  • Ole Fretheim
    Can anybody help me to identify these AC Delco brakes parts?
    They are named as rebuild kits, and are probably for the calipers.
    I need to know if they can be used for rebuilding the calipers of
    my `68.
    Here are the numbers:
    1#173-105 5467288 61081
    1#173-105 5467288 63071
    1#173-105 5467288 71971
    1#173-105 5467288 40031
    Thanks!
    • 43240
    Re: AC Delco brake parts
    Ole-----
    The kits that you mentioned are the caliper piston repair kits for the REAR calipers of your 1968 Corvette. 1 kit is required to do 1 piston. So, you need 8 kits to service both rear calipers. By the way, the last 5 digits of each of the above lines is irrelevent. The kits are identified by the Delco part number (173-105) or the GM number (5467288).
    • Ole Fretheim
      Thanks.
      Seems I will have to purchase repair kits for the front calipers.
      Ole
