block and journal question - NCRS Discussion Boards
  • Charles M.
    • March 1, 2002
    • 155
    Car is a 64 NOM. The block is on a stand but still mostly together. Block is a 3858174, found this number on drivers side top near bell housing, and I think cast C 29 6, found on passenger side in same place.
    Some facts:
    The heads have 1966 casting dates.
    3858174 is generally considered to be a 1966-7 unit.
    My pad stamp is F04I2HCH, thats all.
    Questions:
    Exactly where should I find the block casting date?
    If this is a 66-7 crank in this 66-7 block will it be the large or small journal?
    Isn't it most likely a 2-bolt main?
    • 43240
    Re: block and journal question
    Chuck-----
    The casting date for small blocks is found on the bellhousing flange on the passenger side as you've found. "C 29 6" means March 29, 1966.
    All pre-68 small blocks were "small journal" and that includes the block casting that you have.
    ALL small blocks through 1968 were 2 bolt main bearing. No originally configured GM small block engines used 4 bolt mains until 1969 when all 350s with 4 barrel carb and 302s got them. No 265, 283, or 327 EVER originally had 4 bolt mains. They can be converted to 4 bolt main configuration using aftermarket-available parts. GM never made 4 bolt bearing caps for the "small journal" cranks. 1968 327s can be converted to 4 bolt using 1969+ 350 4 bolt main bearing caps, though.
      • May 31, 1974
      • 8396
      it'll be a 2 bolt main. its out of a pass car or truck based on no vin derivative. use the HCH suffix to determine exact application(i use old Motor Manuals to look up suffix). mike
      • Charles M.
        • March 1, 2002
        • 155
        So far no one has found this suffix in a reference.
        • John P.
          1956-57 Team Leader
          • April 30, 1992
          • 64
          The lime book shows the HCH suffix as a '66, 327ci, 275hp passenger car motor originally configured with a Holly 4B and powerglide.
          • Tom D.
            • September 30, 1981
            • 2135
            PG '66 Pass Car with 327-325 HP ( if HCH) *NM*
            https://MichiganNCRS.org
            Michigan Chapter
            Tom Dingman
            • Tom D.
              • 2135
              Corrected to 327-275HP ( if HCH) *NM*
              Michigan Chapter
              Tom Dingman
