Late '63 Top Ignition Shield - NCRS Discussion Boards
  • Gordon Peterson #4961
    Okay all you late-63 owners, where does your car fit into this?
    When I bought my '63, it had a top ignition shield with three metal rivets holding the insulator. It has always been my understanding that this is correct for roughly the latter half of the '63 production run. The two metal rivet version of this shield is for the '64.
    This belief has been reinforced by the '63/64 JM where on p. 104, it says, "In 1963 models, three stainless steel rivets secure an opaque mylar insulator..." Then further along, it says, "In 1964 models, two metal rivets are used to secure the opaque insulator." So far so good.
    In checking Nolan Adams' restoration guide for other info this afternoon, I stumbled upon the apparent fact that the two metal rivet top shield was used in all late 63's as well. This is from the very bottom of p. 164:
    "The 3848306 (i.e. two metal rivet) shield was first reported by 30867S120390 (20,390). After its introduction, the 3848306 shield was used for the balance of 1963 and through 1964 production."
    My baby is number 21,102, and Nolan is saying I have the wrong top shield. This overlap is not surprising (I see it a lot), and I'm certainly in no position to disagree with Nolan. But could someone with a late '63 please verify that they have the two metal rivet top ignition shield design?
    Could you also verify that you have an EXTRA two metal rivet shield that you are willing to part with?
    Thanks as always for your insight!
    Pete
  • Mike M.
    • May 31, 1974
    • 8379
    Re: Late '63 Top Ignition Shield
    Pete: don't get rid of the 3 rivet and don't spend a fortune for the 64 style 2 rivet top shield as i don't believe you'll have trouble having the late 63 judged with the 3 rivet shield. If you stumble across a 2 rivet critter at a reasonable price, go for it. two of my 63's are late ones( 20301 and 20813) and they both have the 3 rivet shields and i'm 99% certain they are the original top shields for these two 63's. I suspect that if 20390 definitly left st louis with a 2 rivet top, then the balbance of 63 production probably left with either the 3 rivet or the two rivet. (radio equipped , of course). regards, mike
    • Tracy C.
      • July 31, 2003
      • 2739
      Hi Gordon,
      I have 20382 and a 3 rivet top shield. I echo what Mike sez..(kinda hate to admit it though cuz sometimes he really hangs it out there. )
      I doubt you catch a lot of flak over this because the Judging Guide is on your side. As long as you have the "T" style grounding clip, I think you're good to go.
      tc
