C3 plenum duct - NCRS Discussion Boards
C3 plenum duct
  • kelly theaker
    C3 plenum duct
    . I am about to install the dash pads and a seal is shown in the AIM that seals the plenum and the plastic extension routing to the dash pad and deflector was a neoprene or same as the deflector ball -a cotton/? I can only see the remnants of the seals backing or glue .
  • Tom R.
    • June 30, 1993
    • 4100
    Re: C3 plenum duct
    You may need to be a bit more descriptive...not clear if you are referring the air duct plenums, the fresh duct plenums or something related to the dash which shouldn't have plenums. The cotton ball stuff with sticky backing sounds like the weatherstriping used inside the air ducts that glue to the duct then insert inside another duct.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
      • 43237
      Re: C3 plenum duct
      Kelley----
      The original seals were gray foam with pressure sensitive adhesive (PSA) backing. I believe that Dr. Rebuild sells these seals.
      • kelly theaker
        Re: C3 plenum duct
        Thanks tom , the fresh air duct on a non air car , not the floor , but the dash vent , ,i believe the question has been answered and thanks for the help.
        • kelly theaker
          Re: C3 plenum duct
          thanks joe , apreciate the help , thanks.
