Are these "hump fuelie" heads or not? - NCRS Discussion Boards
  • Charles M.
    • March 1, 2002
    • 155
    2 pictures.
    The owner isn't sure about the inboard angle cutoff spot.
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Are these "hump fuelie" heads or not?
    No they aren't. The double hump have two curved bumps. Pop the covers and see what the part number is. Double hump are 3782461. They were used from 62 - 65. They had either 194 or 202 valves based on the horsepower. 250 and 300 had the small valves. The high performance engines had the 202 valves and solid lifters.
    • Loren L.
      • April 30, 1976
      • 4104
      Yes & No..they are Tonawanda Camelhump
      heads - but not suitable for Corvette...just like the ones Chicago Corvette
      Supply tried to sell me a number of years ago............
      • Terry D.
        • May 31, 1987
        • 2696
        461X didn't have big valves did they? *NM*
          • 15696
          Re: 461X didn't have big valves did they?
          461X heads were equipped with 2.02/1.60 valves on '64 and '65 SHP/FI engines.
          You can lump the term "fuel injection heads" into the same category as "numbers matching" and "all original". The only true FI heads are the 461X as they were used on all FI engines from '6l to '65. Virtually all later casting numbers with 2.02/1.60 valves are called "fuel injection heads", but they were never used on fuel injection engines.
          • John C.
            • January 1, 2001
            • 171
            The Boss don't know Jack
            I always cringed at this line from Bruce Springsteen's "Racing In The Streets": I got a '67 Chevy with a 396, fuelie heads, and a four on the floor.
