Check Valve - NCRS Discussion Boards
Check Valve
  • Earl G.
    • September 30, 2001
    • 66
    Check Valve
    Can somebody tell what this check valve was used on, #1-22048221.
    Gunner
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Check Valve
    a lot of chevy cars but NOT corvettes,the list is too long to post
    • Earl G.
      • 66
      Re: Check Valve
      Hey Clem, what years?
      Gunner
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Check Valve
        go to google type in "22048221 valve" for a listing
          • 43241
          Re: Check Valve
          Earl-----
          GM had a PLETHORA of part numbers for these check valves and I'll never understand why. They are a very simple device and are not, in any way, a "calibrated-type" valve. They simply prevent backflow from the exhaust to the AIR pump. The only reason for a difference that I could see would be to have different size fittings on each end. I don't know why even this woulld have been necessary, but, if it was, then that could create a few part numbers for the various combinations of fitting sizes.
          In any event, the GM #22048221 was, as clem mentioned, never used on a Corvette. It was used on some full size Chevrolet passenger cars and Chevrolet and GMC trucks as well as some other GM cars. It is interchangeable with GM #22017478, GM #22040897, and GM #12562568.
          Curiously, the GM #22048221, although it was never used in PRODUCTION or catalogued as a SERVICE replacement part for Corvette applications, does have an appearance and configuration which is virtually identical to the Corvette valves. How it differs I do not know. But, I'd like to.
          • Earl G.
            • 66
            Re: Check Valve
            Thanks Joe,
            Earl
