67 tires sizes - NCRS Discussion Boards
67 tires sizes
  • Justin N.
    • February 1, 2004
    • 318
    67 tires sizes
    Dear members,
    I was curious about running the BFG Momentums for my daily driver on the 67 bolt-on wheels. I want to purchase the 215/70/15 to keep the speedo acurate, as I think this size is close to the 7.75x15 original tires. Has anyone run wider tires in the rear like 225 with 215 in the front? Will this screw up speedo accuracy? Thank you much for the responses!
    Justin #41362
    • 15674
    Re: 67 tires sizes
    215/70R-15s are speced at the exact same revs per mile as the OE 7.75-15, so speedometer accuracy will not be effected. They are a snug fit in the wheel wells and a 6" wide wheel is adequate width. Go with 215/70s all around. In this size there are high speed rated tires available - up to "W".
    • Justin N.
      • February 1, 2004
      • 318
      Re: 67 tires sizes
      Duke,
      Thank you much for the info!Hope to see you at S.L.O.
      Justin #41362
