'66 BB ENGINE REMOVAL - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    If the fan, clutch and H20 pump are removed, is it also necessary to remove the radiator, support and shroud to remove the engine or does it just make it easier? (I realize they can be removed in one piece, but I'd rather not if it isn't necessary)
  • Tom D.
    • September 30, 1981
    • 2135
    I sure would. Hate to bust a radiator. *NM*
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Gary S.
      • July 31, 1992
      • 1632
      Re: '66 BB ENGINE REMOVAL
      Radiator, yes! Shroud, yes! Support, no. Way to easy to remove the radiator rather than risk the radiator.
      Just my opinion.
      Gary
      • Tracy C.
        • July 31, 2003
        • 2739
        Rob,
        Your radiator support also serves as the body support for your entire front end. Leave it and remove everything between it and the engine.
        good luck,
        tc
