metal/rust stripping - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    Any source in Detroit area to de rust some metal parts? I cannot find either redi-strip or chem strip.
    thanks
  • Jerry J.
    • November 1, 2000
    • 54
    Re: metal/rust stripping
    Chris; Are you looking for Chemical dipping or bead blast ????
    We used a company for dipping out near Romulus.. If you need name, I will try and find out in files...
    • Jack J.
      • July 31, 2000
      • 640
      Re: metal/rust stripping Romulus,Michigan
      I.P.S.(International P??????? S????????. Jerry, hope this might help remembering the name. Sorry that's all I could remember,(sometimer's affliction.
      • Jerry J.
        • November 1, 2000
        • 54
        Sorry guys, Receipt is in file at home.. Will bring it in tomorrow..
          The outfit in Romulus has changed hands (and names) in the last year; it's now called "Ready-Coat", and they do stripping and e-coating. (734) 771-3190, ask for Mark
          • Tracy C.
            • July 31, 2003
            • 2739
            Chris,
            Depending on the size of the parts, to can do this yourself with muratic acid and a couple of 5 gallon buckets.
            If you check the archives (or Google) you can probably unearth some good info. If you can't come up with it let me know. I'll search and try to help as well.
            good luck,
            tc
            • Jeffrey S.
              • May 31, 1988
              • 1882
              Tracy:
              I have used Ace Stripping in Hazel Park (I think)and they were very good and reasonably priced. Hope this helps.
              Jeff
