C2 Rear Sway Bar - NCRS Discussion Boards
C2 Rear Sway Bar
  • David Maxwell
    C2 Rear Sway Bar
    I am confused, Is the original rear sway bar supposed to be straight across or have small bends in it. I have saw both on ebay. They 1 that is straight says it is the real original and not the 68 and up reproduction. The other one has to small bends in it and that guy also says it is original. Paragon seems to agree with the straight one. Does anyone here know?
  • Mike M.
    • May 31, 1974
    • 8385
    Re: C2 Rear Sway Bar
    assembly manuals, back in the big block rpo section illustrate the c-2 rear sway bars common to the mark 4 equippped c-2's. mike
      • 43221
      David------
      The original 65-67 rear bar was "straight". I'm not sure about the configuration of the 68-only bar. The 69-74 rear bar had "offsets" in the cross-car section. The 69-74 bar became the SERVICE bar for 65-68 models when the original pieces were discontinued from SERVICE by GM.
