C1 manual shifter finish - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    I have my 4 speed shifter apart to clean up. What finish should I use? I assume semi gloss black. Should I mask the areas that contact each other and then grease? Any hints here would be great.
    I see the chrome ball is worn on both sides. Has anyone ever tried to put a sheet of teflon on the flat bracket itself to take out the slop and some of the rattling?
    thanks
  • Mike M.
    • May 31, 1974
    • 8383
    Re: C1 manual shifter finish
    pretty sure the shifters were natural. i clean, paint with cast blast then lubricate./ god luck, mike
