Re: Leaf Spring - NCRS Discussion Boards
Re: Leaf Spring
    • 15676
    Re: Leaf Spring
    Old, compressed spring link cushions are the most common cause of rear
    ride height sag. If the spring is at least flat, just replace the cushions - less than a one hour jobs and 10 bucks worth of parts.
    • 15676
    Addendum
    It sounds like the liners are clearly worn, so a spring overhaul is due.
    • William V.
      • December 1, 1988
      • 399
      Re: Leaf Spring
      Just bought a box of 10 spring link cushions from chevy for around $12. Compressed cushions cause many problems like hight sag, hard ride ect, so it's a good idea to keep them around.
      • Michael B.
        Infrequent User
        • August 31, 2001
        • 13
        GM Part # for Spring Link Cushions
        Bill, Do you happen to know what the GM Part # is for the Spring Link Cushions?
        Thanks - Mike
        • William V.
          • December 1, 1988
          • 399
          Re: GM Part # for Spring Link Cushions
          Mike
          some parts that one may want to keep available are as follows:
          Spring link cushion qty 10 (3831586)
          Spring link retainer inner
          (connects to spring and trailing arm) Qty 10 (3910701)
          Spring link kit (14029851) provides 2 bolts, 2 nuts, 4 outer retainers, 4 link cushions, 2 cotter pins and 2 inner retainers.
          the part number for lock half shaft u-joint flange qty 5 is 3860543.
          Hope this helps.
          Good Luck
          • Michael B.
            Infrequent User
            • August 31, 2001
            • 13
            Thank You Bill - I appreciate it!
