Holley carb problems - NCRS Discussion Boards
  • William P.
    • September 30, 2003
    • 30
    I have a 71 LT-1 that I am having problems with the 4801 carb. It started hesitating upon acceleration so I rebuilt the carb, and now it runs very rich. (black smoke and won't idle) At full acceleration it runs fine, but at a crusing throttle position it bucks and I can see black smoke in the mirror. Any ideas?
    Thanks in Advance
    Bill Pearson
    red/red 62
    71 LT-1
    #40831
    pearwill@comcast.net
  • Dave F.
    • December 1, 2003
    • 508
    Re: Holley carb problems
    Had the same problem with a Holley on a non-Corvette application. Major float adjustment is what you need to do.
    • Jim T.
      • March 1, 1993
      • 5351
      In rebuilding the carb did you replace the power valve? Running rich like you say I am thinking that the power valve is ruptured and not functioning.
      Quick test. Remove the top of the air cleaner. Start the car. Now put a finger over the veritcal vent tube. If the car stumbles and dies replace the power valve. When you start your car and it backfires, there is a good chance that it will destroy the power valve. Newer Holleys have a anti-backfire protection with the use of a small ball bearing look alike piece. Holley power valves can be purchased individually at Auto Zone.
