71 454 Condenser Mounting Hardware - NCRS Discussion Boards
  • Frank B.
    • April 30, 2002
    • 66
    Since I received no responses, thought I would try to make it brief and see what happens. What is required to mount the condenser to the Radiator soupport?
    How are the the washers/cusions arranged arranged on the bolts on the top of the condenser mounting tabs. The assembly manual is not clear as to the size, type or placement of the washers.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 71 454 Condenser Mounting Hardware
    Frank I have a 70. I will tell you how my original owner 70 has its air conditioner condensor mounted if you still need the information. There is some menitoned in the the archives about this about a year or so ago.
