71 Big Block Condenser Mounting - NCRS Discussion Boards
  • Frank B.
    • April 30, 2002
    • 66
    As Viewed from the Front could someone tell me what hareware, bolts, washers, ect are used to mount the upper taps of the condenser to the Radiator Support.
    I have looked at the assembly manual until I am blue in the face. I have also purchased several mouinting kit with each having different sizes of bolts and washers. From what I can determine the upper radiator hold down plates or (Plate assy) as called in the assembly manual were attached on the right side with two bolts and star type lock washers. The left side was a little different in that only the left bolt had the star washer the right one had a flat and a lock type washer. When looking at the condenser mounting the two inner bolts and washers are different. This is were the confussion come into play. The assembly manual shows two flat washers on the left side, one between the condenser mounting tab and the radiator support and one on the outside of the tab, and the mounting bolt. The right side shows only one flat washer on the outside of the tab with the bolt. I am loking at LS5 B5 Radiator and C60 B1 AC Concenser.I would also like to know the diameter of the washers, each kit I have purchased has a different size. Keep in mind I am discribing this looking from the front. If someone out their has a unmolested LS5 with AC I would appreciate some feed back. Additionally the Judging manual states that rubber bushings were used between the condenser mounting tabs and the support,however I can find no evidents of thisfor model year 1971.
