67 Interior Door Panel Removal - NCRS Discussion Boards
  • David G.
    • December 1, 2002
    • 99
    Need to remove 67 interior door panel to repair window trim. Used large crank removal tool to pop pins on both window cranks, but no way this tool will fit inside the recessed lock knob on my door panel. The lock knob is pretty tight against the panel. Is there a different tool or technique to remove the lock knob?
  • Ed Jennings
    Re: 67 Interior Door Panel Removal
    I use some small needlenose pliars and a pick-like tool with a hook end to get the clip started.
