66 Steering Column Jacket - NCRS Discussion Boards
  • Tom Blount
    I am about to repaint the steering column jacket on my 66 big block after renewing the upper and lower bearings, turn signal switch, etc. Can someone tell me the correct color to repaint it? The part of the column that will be exposed in front of the instrument cluster should probably match the semi-gloss interior finish, but should the part of the column that protrudes into the engine compartment be semi-flat black? It doesn't seem feasible that in production, they would paint this jacket two different colors. Logically the entire column would be one color, probably semi-gloss black. Can anyone confirm that? What is the best source of the proper paint? Thanks.
  • Bill W.
    • November 1, 1977
    • 402
    Re: 66 Steering Column Jacket
    Mornin' Tom, You are correct, the whole column is simi-flat black. I have used Krylon #1361 or is it 1631? The color is perfect, though I wish durability was a little better. Maybe someone else will have a better choice for you. Bill
    • Bill W.
      • November 1, 1977
      • 402
      • Tom B.
        • February 1, 1994
        • 779
        Bill & Tom,
        It's #1613, and I used the same thing on the same thing. Tom #24014
        • Tom B.
          • February 1, 1994
          • 779
          Bill & Tom,
          • Gene M.
            • April 1, 1985
            • 4232
            There is a paint VHT semi-gloss that is pretty good for wear areas and looks as nice as the Krylon for color/gloss. Dry time is much longer than Krylon with the VHT.
            • Gene M.
              • April 1, 1985
              • 4232
              • Tom Blount
                Tom, Bill and Gene, thanks for the response. I'll try the Krylon 1613. Much appreciate the help. Tom Blount
                • Tom Blount
