Need help with '56 camshaft - NCRS Discussion Boards
    • 15696
    As part of my ongoing SB camshaft research I've enlisted the support of a well known supplier to the racing industry with an excellent reputation going back over 40 years. We are now looking for a 1956 base engine camshaft, which would include the 210 HP single four barrel engine and 225 HP dual four barrel engine.
    I pretty sure this is a hydraulic lifter camshaft and the part number is 3711354 casting number "355".
    If someone has a new or used camshaft meeting the above description, would you be willing to loan it in order to have it analysed with a Cam Pro Plus camshaft analysing system? The Cam Pro Plus creates a complete data file of lift, velocity, acceleration, jerk, and base circle runnout every crankshaft degree (one half camshaft degree) - essentially a complete reverse engineering of the cam to understand its design.
    If you can help out, e-mail me and I'll put you in touch with above individual to arrange shipping.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Need help with '56 camshaft
    duke that is a solid lifter cam. lash .008/.018,intake opens 21-30',closes 62-30',exhaust opens 62-30',closes 28-30',lift intake .4034, exhaust .4135 this cam was used in the 195,210 and 225 HP engines
      • 43240
      Duke-----
      I don't have one of those and it's going to be a bit tough to find one. The GM #3711354 camshaft was discontinued in July, 1975, so it's been "dead" for almost 30 years. However, you never know, one might "pop up" on eBay.
        • 15696
        I'm hoping that someone has one that they removed from and original engine and saved. A new cam would be best, but a used one would be okay if not severely worn.
        Another identifying feature of this cam is that is has a groove on the rear journal as do all '55-'56 SB cams.
        BTW, the numbers from the Cam Pro Plus on my Duntov cam showed virtually no wear. It's still serviceable, but I already replaced it with a LT-1 cam.
        • Dave Suesz
          Rare camshaft supplier...
          Glazier's Mustang Barn gets rare old cam designs from a manufacturer who has never been stumped by them. I'd be willing to bet if they didn't have the 55-56 cam on hand, they could make one up from their records. Have GMB give them a call!
          • James F.
            • December 1, 1985
            • 596
            Re: Need help with '56 camshaft- Duke
            Duke,
            You have mail.
            • Clem Z.
              • January 1, 2006
              • 9427
              i'll bet jim has his orignal 56 covette cam *NM*
              • James F.
                • December 1, 1985
                • 596
                Clem's right on (as usual)! *NM*
