59 Engine/powerglide - NCRS Discussion Boards
  • Robert D.
    • April 1, 2003
    • 305
    what is the neutral ideal supposed to be.
    on a 245 hp car
    when i put it in drive it slams into gear is that the way these old trans' engaged gear from neutral?
    thanx
    bob
  • William C.
    • May 31, 1975
    • 6037
    Re: 59 Engine/powerglide
    No, it should not slam into gear
    Bill Clupper #618
    • Roy B.
      • February 1, 1975
      • 7044
      You may have your idol to high or the band adjustment wrong.
      • Joe Maulsby
        Re: 60 Powerglide Slamming into Gear
        Roy, my car has slammed into gear since I bought it in 1989; just thought that was "normal." I have the idle set low (@ the rpm that the operators manual books calls for). Are the bands too tight or too loose when this occurs? Is this a simple fix for a transmission shop or a major tear down?
        • Roy B.
          • February 1, 1975
          • 7044
          Trans shop simple, the band adjustment is on the out side R/S. sound to me it may be to loose. Read and look in an old book. If you can put gas in your Corvette , then you can adjust the band. Or if the vacuum line going to the modulator is leaking or the modulator is bad this will also cause it,the part is cheep and again you CAN DO IT.
