1962 corvette - NCRS Discussion Boards
1962 corvette
  • Brian S.
    • December 1, 2001
    • 8
    1962 corvette
    I have two questions about my 1962 corvette restoration: First, is
    the flywheel inspection cover black or orange? Second, do the 16
    bolt heads for the front crossmember face up towards hood or do they
    face down to the ground? Thanks for your help. (This car is equiped
    with a 327/powerglide.)
  • John S.
    • July 31, 1990
    • 292
    Re: 1962 corvette
    Brian I have a 62 PG car. Inspection cover is orange. The frt cross member bolt's, some are up and some are down. My car is in car jacket right now so I can't tell you which one's. john
    • Ray C.
      • June 30, 2001
      • 1132
      Re: 1962 corvette
      I just requested the same information a couple weeks ago. You should be able to find additional information on this subject in this achieve. On my 1961 the front bolts (grill) had the nuts towards the ground and the four rear bolts had the nuts towards the engine compartment or with the head of the bolts towards the ground.
      Ray #36314
      Ray Carney
      1961 Sateen Silver 270-HP
      1961 Fawn Beige 315-HP
