Headlight dimming - NCRS Discussion Boards
Headlight dimming
  • Timothy B.
    • January 1, 2004
    • 438
    Headlight dimming
    OK, I know we don't actually drive our cars much at night, but I did so around the block recently for the first time since it has been running again. I noticed a fairly significant change in brightness from idle to driving, as the engine speeds up. Is this simply normal for these years with mechanical voltage regs, or is this a sign of a problem with my regulator?
  • Dave Suesz
    Been there...
    When your engine drops to idle, the alternator "stalls", that is, it's not turning fast enough to produce 14v. Ordinary passenger cars use itty-bitty pulleys on the alternator to prevent this, but on a performance engine this would be brutal punishment at high engine speeds, prob'ly cause small parts to fly off the alternator or smoke to come out of it, or something.
    • William V.
      • December 1, 1988
      • 399
      Re: Alternator wipe-out
      Dave
      I hand the incorrect alternator pulley on a 1965 396. When I went through the gears near redline the fan blades on the pulley bent out of shape.
      It's common to wipe out alternators at high RPM.
      • Dave Suesz
        Exactly...
        Repro large-diameter alt pulleys are available for both Chevys and Fords. Funny thing, they seem to be almost identical. "Form follows function"?
        • Joe C.
          • August 31, 1999
          • 4598
          Re: Headlight dimming
          Tim:
          If everything is operating correctly, and you have the proper alternator and regulator, then you shouldn't notice "significant" dimming @ idle. As previously mentioned, the alternator will not supply 14 volts at idle. If your battery is weak, this will cause the lights to dim slightly. Increase your idle speed slightly.
          Joe
          • Clem Z.
            • January 1, 2006
            • 9427
            check the voltage at the headlights vs the battery voltage to see if you have a drop in voltage because of a bad connection or high resistance.
            • Clem Z.
              • January 1, 2006
              • 9427
              PS this should be done with the lights on *NM*
