I have what I believe to be a 1965 wheel with original paint. It's what I would call a semi-gloss black. There is not very much paint and lots of press markings and etc. showing "behind" the paint. Inside, Back and front all appear to be the same color. Sound right?
There is also some hardened caulk (or the like) that appears to have drained from the disk to outer rim connection to the the outer rim (in one area). I have seen this one other wheels as I cleaned them up.
I've seen 1967 style wheels with almost a "bead" of caulk. Was some sort of primer or caulk used? If so, why and how applied?
Tom D.
www.MichiganNCRS.org
Tom D.
