T10 tailhousing types - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    My T10 tailhousing in my 62 340 has a broken flange on the mount. There was a bolt coming down with a nut instead of threads in the casting for a bolt going up.
    It says T10-7D and I could not find any casting numbers on the outside. I was talking to someone who seemed knowledgable and he said that there were many different tailhousings with that number and that they were different dimensionally.
    He had me measure from the front of the tailhousing to the center ot the mount. Mine measured ~4.25". It also has 5 mounting flanges for shifters.
    Can someone give a little history on T10 tailhousings? I have talked to about 3 other vendors and none have mentioned this difference.
    thanks, Chris
  • William C.
    • May 31, 1975
    • 6037
    Re: T10 tailhousing types
    essentially by '62 you were down to two types in general usage, the single mount style and one with two mounting pads on the bottom of the mount, all had the five bolt holes for ****fter mounts in this era. The correct mount for your '62 is the single mount style, that is why the adapter was used from the trans mount on the frame to the mounting location on the tailhousing for '62. In addition to the T10-7D you should also have a date on the passenger side of the housing.
    Bill Clupper #618
    • Chris H.
      • April 30, 1990
      • 817
      thanks. I have a 10-10-61 date. So far the closest I have found is 8-16-61 which I will probably go with.
      Chris
      • William C.
        • May 31, 1975
        • 6037
        What is the VIN of your car?
        Bill Clupper #618
        • Chris H.
          • April 30, 1990
          • 817
          VIN 208675102654 11-12/13-61
          engine F1028RE 10-28-61
          block 9-22-01
          trans WL31-2 11-3-61
          tail 10-10-61
          • William C.
            • May 31, 1975
            • 6037
            Shouldn't be a problem, my trans (original to the car) Has 8-15-61 side cover and 8-1-61 tail on S/N 1843 car.
            Bill Clupper #618
