Tree valve, how to check - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    I am searching for a vacuum leak on my 71. Can someone tell me how to check the tree valves. I have 3 of them out of the car.
    Here is what I have done.
    If I put pressure to the center stem and cover the stem farthest from the valve air leaks out of where the valve stem sticks out of the tree. I think there was a filter of some sort on that end. Is air supposed to come out?
    The tree under the right fender leaks more air than the headlight trees. If no air is to come out then I will get 3 new trees.
    Thanks in advance
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: Tree valve, how to check
    That's a filter.
    • Ralph A.
      • May 31, 2002
      • 236
      Re: Tree valve, how to check (Confused)
      I figured that, but is air supposed to flow freely when a vacuum or pressure is applied at the center stem? I thought this was a sealed system and the tree valve switched between the center and either side outlets. I fair flows thriught this end then it seams you will never achieve the pressure need to activate the actuators.
      Please elaborate.
      RA
      Ralph Adams
      NCRS: 38137 LA: 112
      Slidell, LA 70461
        • 11622
        Ralph,
        The Dr. Rebuild book describes how to properly test the valves. I don't recall the exact method (my book isn't handy) but in a nutshell I believe the answer is no, air is not supposed to be able to flow out of the filter end.
        These valves aren't cheap, but I've replaced all 3 on my 71 and Dad's 72 due to leaking. It made a big difference. For whatever reason, all 3 on my 72 seem to work just fine.
        Patrick
