how to determine intake closing angle - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    I am trying to determine the dynamic compression ratio of an engine. How is the intake closing angle determined? The pages all act as if it is just known for a cam. Is it easily calculated from the advertised intake duration angle?
    Chris
    • 15695
    Re: how to determine intake closing angle
    It depends on how the closing point is defined. SAE J604d defines the valve events at .006" valve lift. Another way to define the valve events is "lash point". The difference for typical cams for each of the four events is 5-10 degrees.
    Most aftermarket cams use the SAE J604d for "advertised duration", but you need to know the centerline to determine the actual open and close points and this is often not specified.
    Vintage OE cams dont's use either of the above two conventions.
    • Clem Z.
      • January 1, 2006
      • 9427
      check for the timing specs on these OEM cams that are reproduced by crane and F/M by checking their catalogs or websites
