Valve Lash - NCRS Discussion Boards
Valve Lash
  • William P.
    • September 30, 2003
    • 30
    Valve Lash
    Hello all:
    I recently purchased a 71 LT-1 and need to set the valve lash clearances. Does anyone know what the factory specifications are for this?
    Thanks in Advance
    Bill Pearson
    40831
    Red/Red 62
    71 LT-1
    • 43221
    Re: Valve Lash
    William-----
    Intake---.020" (hot)
    Exhaust---.025" (hot)
    The information provided in some references, including Chevrolet Service Manuals, calls for .030" on both intake and exhaust. This is incorrect.
      • 15674
      Re: Valve Lash
      I recommend .021"/.026" based on the ramp heights of .016"/.020" and the actual 1.37:1 rocker ratio at the lash point.
      GM recommends .024"/.030", but that's based on the "advertised" rocker ratio of 1.5:1. The .030"/.030" recommendation in some service manuals is the GM recommended clearance for the old 30-30 cam based on a 1.5:1 rocker ratio, so it's wrong on both counts.
      The spec sheet that is included with Speed Pro LT-1 cam clones says .020"/.025", which is okay, given that base circle runout is typically a thou.
      The clearance tends to loosen with mileage accumulation.
