C1 Teeth - NCRS Discussion Boards
C1 Teeth
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12784
    C1 Teeth
    Hi all,
    Does anyone now a method of identifing the different grill teeth, do the have a number on the inside or is there another way to distingish them ?
    greetings,
    Rob.
    Rob.
    NCRS Software Developer
  • Garry Barnes
    Re: C1 Teeth
    Rob,
    They have a number on the inside along with the smaller part number, both cast into the inside of the tooth. You should find numbers 1,4,5 and one being a C for center. There are no 2's or 3's. You should have 2each of #1's, 4each of #4's and 2each of #5 with one C. 5 4 4 1 C 1 4 4 5
    Garry
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12784
      Re: C1 Teeth: Thanks Gary ! *NM*
      Rob.
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12784
        Re: C1 Teeth
        Gary (and others),
        I didn't find th ementioned numbers or C on the inside of the teeth but I did found some serial numbers ending on #424 #427 and #428. Also I find two teeth with a round hole drilled in the te lost number #42?. How can I determine the correct teeth dfor the C, 5's, 4's and 1's ?
        greetings,
        Rob.
        Rob.
        • Garry Barnes
          Re: C1 Teeth
          Rob,
          According to the Judging manual: 3706424 is your Center tooth
          3706425 are your #1's on each side of the center tooth
          3706427 are your #4's and are the next two on each side of you #1's
          3706428 are your #5's and are at each end.
          *special note-some #5's may not be stamped "5" however the part number 3706428-9 will appear.
          Garry
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12784
            Re: C1 Teeth
            Thanks gary, that's exactly what I needed !
            greetings,
            Rob.
            Rob.
