Transmission ID - NCRS Discussion Boards
Transmission ID
  • Steve H.
    • November 1, 1996
    • 118
    Transmission ID
    Can anyone help me identify a transmission that I removed from my '56? It is a GM 4 speed with the following numbers. Main case cast #3925560, also stamped on the right side the flange 18S421311 and in larger case P8E22? the tail shaft has cast # 3857584, and the cover has cast # 3884685. Any help wuld be appreciated.
    Steve # 28428
    • 43221
    Re: Transmission ID
    Steve----
    I think you'll find that the main case casting number is 3925660. Anyway, the transmission is a 1968 Muncie. Based upon the NIN derivative, I believe that it was originally installed in a late-build 1968 Corvette.
    • Steve H.
      • November 1, 1996
      • 118
      Re: Transmission ID
      Joe, You are correct,it should have been #3925660. Thanks for the response.
      Steve
