Early '59 hood release cables - NCRS Discussion Boards
  • Pat #25912
    What is the proper routing of these cables through the firewall. The AIM (sect 11 sheet 2.00) shows the routing for I believe late '59 through '62 where the cables pull the release lever horizontaly towards the firewall. The early '59 latch release pulls the lever downward. Do the cables use the same firewall exit locations for all years or are there different holes for the earlier cars? Thanks again. Pat G.
  • Jim Kay
    Re: Early '59 hood release cables
    Pat-I have the same dilemna. I'm wondering if the '58 AIM would show the correct routing. Anyone out there that can help us?
    Jim #4281
    • Pat #25912
      The '58 AIM is a good idea Jim, thanks. I thought I might be imagining things. If you figure it out let me know and I will do the same for you. Pat G.
