1963 fuelie ? - NCRS Discussion Boards
1963 fuelie ?
  • Tim M.
    • March 1, 2004
    • 24
    1963 fuelie ?
    I am looking at a 63 conv. that has the engine and fuel injection system out of a 64. The car has the 6500rpm tach and fuel injection emblems, but I am not convinced that this car started it's life as a fuel injected car. Are ther signs that I can check to determine for sure if this is a genuine fuelie?
  • Mike McKown
    Re: 1963 fuelie ?
    There are a lot of things to look for. The problem is, they can all be duplicated, easily. It's kinda' beside the point anyway if it has has the later engine. By the way, if you don't want it, e-mail me with the whereabouts. I might want to buy it.
    • Joe S.
      • July 31, 1999
      • 319
      Re: 1963 fuelie ?
      Like Mike said, everything can be duplicated, but a few things to add:
      Radiator Support hole for the FI Air Cleaner (later service replacements also had the hole though).
      Holes in driver side inner fender for mounting of air cleaner.
      Must be manual transmission and posi rear (3.55, 3.70, 4.11, 4.56).
      Exhaust manifolds (driver side choke tube)
      Idler Belt
      MEchanical Lifters
      Double Hump Heads
      Some of this may not apply with the engine already being replaced.
      Joe and Joanne's 63 FI Convertible
      • Bill Jackson
        Re: 1963 fuelie ?
        Look closely at the radiator support. I have been told that a 63 FI radiator support was different and never sold over the counter and is different than the later 64-65 and replacement style. Look for two bump outs (2 x 4 inches) where the horns mount plus the big hole for the air cleaner. My 63 FIs match this description.
