C/3 window regulator - NCRS Discussion Boards
  • Ed P.
    • July 31, 2002
    • 270
    I took apart passenger side door to repair manual window regulator. I found that bolt fell out of fwd window causing all my binding problems. I decided to remove everthing and clean it up and regrease tracks. My question is what grease would you recommend for the window tracks and plastic rollers. Thanks Ed
    • 43221
    Re: C/3 window regulator
    Ed-----
    Lubriplate or similar white lithium-based grease.
    • Chuck S.
      • April 1, 1992
      • 4668
      Joe, I know they used Lubriplate type grease in this application at the factory, so what characteristic of the white grease makes it better for the regulator application than using a lithium based chassis grease? Suppose the General was after minimum winding effort? Maybe because this is a low stress application and it's cheaper than chassis grease?
      I am not a big fan of Lubriplate after seeing it dried out in some applications. I could break it off in chunks, and scraped the residue off. I suppose 30-40 years is a long time to expect a grease to maintain its lubricity.
        • 43221
        Chuck-----
        The Lubriplate-type grease is what GM recommended be used for the application in service. So, that's what I use. I think that regular chassis grease would work as well, though.
        Just about all greases will deteriorate as you described over time. Basically, grease is a compound made from a soap and an oil. When the oil has "seperated and gone" what you're left with is the soap. That's the "gunk" that you described.
