'67 TRI PWR CENTER CARB ADJUSTMENT - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    The engine actually slows down momentarily, rather than accelerating during the initial opening of the throttle from idle. Assuming this is a function of the idle mixture, does this indicate too rich or too lean mixture? (The carb is a freshly, rebuit original).
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: '67 TRI PWR CENTER CARB ADJUSTMENT
    More likely too lean and the accelerator pump needs adjustment.
    • Wayne K.
      • December 1, 1999
      • 1030
      Rob,
      I say lean but if the car idles fine I think you may need to adjust the acc pump as you may not be getting a good shot coming of idle if in fact it is a carb problem and not related to timing or ignition advance.
      Wayne
      • Rob A.
        • December 1, 1991
        • 2126
        I do see fuel squirting in. I need the idle mixture screws what I think is quite a ways out, about 4 turns for it to get better. The plugs look fine, though, not wet, no matter how rich I make the idle mixture. How is the acc pump adjustment made?
